How long to warm up 803a before 75% load?
Farmitall
276
Eubank, KY
One of my 803a sets bogs badly to the point of stalling when resistive load of 75% is switched in after about two minute warm up.
When first starting,it seems like it has low compression and takes several seconds to fire up and come up to speed. I understand that there is a delay to build oil pressure but the delay seems excessive to me.
It seems like retarded timing or low compression to me....I don't know for sure.
After a warm up period everything is smooth, the exhaust is HOT and everything runs fine with 43 amps load ( 120/240) L1-L3 load terminals.
My question is: How long do these need to warm up before application of a significant load?
Tom
Light in the Dark
5,511
MA
I let the machines get up to operating temp, before I ask anything of them. I don't know if there is an established time.
kloppk
3,253
Pepperell, Massachusetts
The -10 TM suggests letting the set warm up for 5 minutes.
From the TM...
Under normal conditions warm up the engine without load for five minutes.
(If required, load can be applied immediately.)
Light in the Dark
5,511
MA
There you go. Unless I find myself in a hellish storm where I just need to get back up ASAP... I can give it 10-15 min to cruise.
Farmitall
276
Eubank, KY
Thanks for the replies gents!
I normally do warm my sets up before applying a load but was curious as to performance while cold......now I know...it bogs.:-(
DieselAddict
1,903
Efland, NC
If I were to design the ideal warmup sequence it would look like this:
From start to coolant temp = ~100 degrees - No load
From 100 degrees to full operating temp + 5 minutes - 25% load
Adding a little load once all the fluids are circulating and starting to come up to temp helps diesels generate extra heat and bring it up to temp faster. I don't like to have a machine like this in an operational condition that can allow moisture to hang around if it can be avoided.
Farmitall
276
Eubank, KY
Thanks....that sounds very reasonable and I will adopt that as my new procedure.
