How many RPMs should a Humvee 1165 6.5 L turbo
Tackelbarry
Chapel Hill, N.C.
with the 4L80E be turning at 55 mph, roughly? I test drove one that was between 3000-3500 at 55 and 60 mph. It seems like it took too long to shift and it might have a broken band in the trans or not going into overdrive. Thanks for your help.
Mogman
10,271
Papalote, TX
If it has the 400A alt it likely has an overdrive pulley so the RPM will show higher than it actually is, the turbo also has the highest ratio diffs at 3.07:1 so they do rev higher than the A2 trucks with the 4L80
Tackelbarry
Chapel Hill, N.C.
I am completely new. Is there anything to insulate the floor and interior to reduce the engine and Road noise? There is no way my wife will ride in this thing as loud as it currently is.
I have not bought the truck yet, but am seriously considering buying it. Anything else to look at? Thanks again.
20,512
Yes! There is plenty of sound deadening materials - some with "sticky back" that you can peel off and stick to the inside of the "doghouse". That will cut out a lot of noise from the engine. Then a little more under the seats and maybe a little in the bed of the truck as well. Spray bed liner will help insulate the sounds as well.
There are a ton of threads on sound proofing your vehicle...
Tackelbarry
Chapel Hill, N.C.
like I said, completely new to this. Is the dog house the engine cover that attaches from the inside? Also, has anyone done a transmission swap to a 6L80E to reduce rpm’s for highway driving? Would it help and hold up?
HoveringHMMWV
1,320
AL
3000-3500 seems way high at 55mph. My 1151A1, with a 200amp alt, is only running approximately 2100-2200 @ 55mph.
Mogman
10,271
Papalote, TX
I did, it is a much better transmission that the 4L80 as far as efficiency goes and is just a strong (hence the 80 rating)
It is allot of work and some of it is custom so not something you can get done "down the road" (or anywhere for that matter, you have to do the custom work yourself)
Here is the build thread
As far as I know I am the only one that has installed a 6L80, there was a company that claimed to be coming out with a "kit" but that never came to fruition again as far as I know.
Coug
4,594
Olympia/WA
If the truck is idling and the tach reads 900+ RPMs, then it's extremely likely that it has a 400 amp alternator with the small pulley, which makes the tach read about 36% higher than actual RPMs.
At 50mph a truck with 3.08 gearing (any of the turbo motor trucks, most obvious external feature is the front grill sticks out about 6" in front of the rest of the hood) will be turning around 2000 RPMs. These were also the trucks that came with the tachometer installed; most of the others it was added on later and less common to see.
With the 400 amp alternator and small pulley the tachometer will read around 3000 rpms, , which does seem close to what you were reporting of 3000-3500 at 55-60mph.
Mainsail
1,763
Puget Sound, WA
Mine is the ECV with the turbo and 400 amp alternator- my idle RPM when warm is around 975RPM, which seems high and feels high (seems like it takes a bit of brake pedal pressure when stopped to stay stopped).
My M1009 CUCV would idle high during warm-up, then once it got to temp there was a noticeable drop in RPM, such that you could easily hear the RPM drop. I don't notice that at all on the M1165, so I wonder if it's not dropping the RPM once warm.
TNDRIVER
555
Cleveland,TN
A JEEP
TOBASH
3,859
Brooklyn, NY
Respectfully, I like to start things from the bottom and work up.
Have you ensured that you are shifting into first and second and third and fourth gear? Have you insured that you are not stuck in limp mode? Have you ensured the transmission lock up is occurring at highway speed and that the brake switch is not interfering? Have you ensured that the throttle position sensor is properly adjusted?
I think you need to go through a lot of old posts on this bulletin board and we have free technical manuals that also contain a huge amount of information.
The first thing you need to do is ensure that your transmission is shifting properly, in my humble opinion
Mogman
10,271
Papalote, TX
Has anyone tried a GPS or other style tach to get a correct reading? Thanks again.
I install a GPS speedo in my HMMWVs, never heard of a GPS tach.
The cure for the error with the 400A alt is to replace the alt with a 200A or the the pulley on the 400A alt, that 400A is a beast and causes other issues with shorted harnesses amd failed mounting bolts.
TNDRIVER
555
Cleveland,TN
Adult in the room time............... It appears you are looking at buying a privately owned truck. I'm going out on a limb here but my guess is that some one is trying to flip a auction truck or got all stary eyed and bought into one only to learn that it is beyond their means either intellectually or financially to maintain.
If you are serious about wanting to own a vehicle that is hot in the summer, cold in the winter, hard to drive. hard to park, gets bad fuel mileage, rides horrible,
will get you thrown out of the student pickup line at school. There are a couple people on this board that can sell you a truck that runs correctly when delivered. My personal favorite being Retired War Horses, but I'm biased. Just pretended I'm your Momma, THINK about it. Free advise is worth what you pay or it. I hope you own tools.
TOBASH
3,859
Brooklyn, NY
I missed the TEST DROVE part until TND’s above post.
I agree with TND!
If you don’t know anything about these trucks and you are driving a truck that is having mechanical issues, you are in for a world of hurt.
Learn, read, and don’t purchase unless you have double the money to work on repairs.
That vehicle has an issue. If you don’t know how to fix it then walk away.
