tequilaiam
- 0
- 16
- Brazil, IN
In looking through the TMs to debug my hard start issues I keep running across temp sensors and switches that all appear in different places. Exactly how many are there? Does the GP controller use the same one that the idiot light does? What about the cold advance switch? i can't tell if they're all different or some of the same ones from the line drawings.
Is there a resistance vs. temperature chart anywhere for the GP controller sensor?
As far as I can tell there is:
*A cold start advance switch somewhere above cylinder 8 (rear passenger side)
*and an engine temperature sensor somewhere under the drivers side valve cover?
(from page 2-63 of the -34 TM)
*a coolant temp sender near cylinder 1 (front drivers side)
(from page 4-35 of -20 TM)
*and yet another temperature switch near the thermostat on the water crossover (page 2-147 on the -34TM)
Have i got that correct? The switch is easy enough to test but what about the sensors/sending units?
Thanks!
Thanks!
