SasquatchSanta
- 18
- 0
- Northern Minnesota
This evening when I pulled a side cover off one of my spare M37 transmissions I discovered it had taken on some moisture and therefore some of the gears have picked up some surface rust.
It seemed to come off with WD40 and steel wool with no apparent pitting BUT, there is some discoloration on the teeth. It's hard to tell exactly what damage was done without stripping the transmission. .
I've always blindly assumed any amount of rust would ruin a gear but maybe not???
A few years ago I had a Jeep transmision that picked up some water that pitted the gears so bad it looked like pieces of chrome flaked off the teeth --- it was toast.
This M37 transmission doesn't have the pitted chrome signs, just discoloration although closer inspection may reveal some minute pitting.
Where do you draw the line on what is acceptable and what isn't?
