expeditionnw
- 2
- 18
- Alaska
So, how much? The 2.27 ton rating on my 1078 Seems laughable.
That's the "offroad" rating. On road should be 5 ton.So, how much? The 2.27 ton rating on my 1078 Seems laughable.
Like on a towbar? Any idea what weight it takes to set the truck on the bumpstops?I pulled 32k from the shackles. With heavy weight the frame has arms with rubber bumpers it squats down and sits on the axles.
Thats crazy. Seems to me this should be able to haul more than my one ton ford.Dragged it on a metal plate on dirt. There was a thread a while back someone used a 1078 to move a lathe that was around 4000lbs if I remember correctly and he was sitting on the axles.
That is true. I may change outRemember, it's built to haul that much weight in off road conditions by soldiers that are rough on gear
IIRC, every vehicle the military has used, they have de-rated the weight rating, except the M880s which somehow raised the weight rating.... Combined and under mil contract, the truck is de-rated. ...
Beyond weight capacities, it is also important to remember CG. Center of gravity on a truck with a bed this high of the ground is much different than the relatively low-riding civvy haulers. They are set up to run on pavement, while the LMTV and other MV's are capable of both on and off road.The payload caps are crazy. Looking at how this is built compared to my international medium duty (which hauls 15k easily) it seems like this thing could easily handle the 20k that the MV/Ts are rated for.
