how to disable air pressure alarm?
ModernDieselLegion
Pasadena TX
M820 A2
Don't flame me yet! I only want to disco it because I have to be in the cab for the next few hours with this big ole guy running and the air pressure alarm is sounding constantly.
HOW DO I DISABLE IT????
KsM715
142
St George Ks
Are you driving it? or just working on it for hours with the motor running? If your driving it I suggest you find the source of the air leak before you drive it. That buzzer is there for a reason. If its constantly going off you have a sizable leak somewhere.
Otherwise just unplug it, it's up under the dash.
rrrr
Missouri
The 9 series is by the drivers left foot with a large cable type plug on top. I disconnected mine to work on the truck. It turns out that mine failed on and I had to replace the unit. I also had an air pressure switch that failed open. Two problems in the system took 2 days to trouble shoot and fix. Now my air system is great !
The unit on the 9 series also has the horn for the parking brake so if you have to move the vehicle don't forget about the parking brake.
ModernDieselLegion
Pasadena TX
no dice on the left foot. she's somewhere at the top center of the firewall under the dash. multiple boxes have two air lines going in and one wire coming off....time to figure this bitch out. thanks for the help guys and i also found the TM's for these trucks.
and not driving it, working on it.
1,174
It has just 1 wire going into it from underneath.
You should be able to hear and feel it, while it's on.
