How to disable surge brakes on trailer
fran35
Southern, pa
Hey guys,
I have what GL listed as an m101A#, but is actually a hodge podge of A2, A3 and A1. Anyway, I use the trailer to haul light stuff mostly, behind a full sized truck. The brakes have been jumping horribly and I really just want to disable the brakes. I have heard about the lockout pin, but can't seem to locate it. At this point, if I simply disconnect the lines from the cylinder, will that give the same result? Thanks, Frank
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
I really wouldn't go that route. There is a hole in the housing(between the two swing bars) of the master that a bolt goes through. It might not go right away, sometimes I have to pivot the assembly to get it to go in.
1,807
Need 3 1/2"of working length for this lockout pin. Lower grades bolts wil bend, use quality stuff.
glcaines
2,494
Hiawassee, Georgia
Hey guys,
Replacing the shock will likely solve your problem. Disconnecting the brake lines will only make a mess and the MC will be banging in and out as the lunette moves if you don't have a pin installed. I would replace the shock or insert a pin.
