How to fix squeaky suspension?
snowtrac nome
137
western alaska
my experience its the hoods that squeak, not suspension components. if yours are likely its too late to grease them, or the rubber components are in your a arm bushings are or weather checked
TOBASH
3,363
Brooklyn, NY
Get some larger friends to lift and depress the vehicle on each side while you are under it to listen.
ALSO, they sell special automotive squeak and knock detection sensors specifically for this kind of issue.
Best,
T
Jericho
69
Landaff NH
I use a SHUTZ spray gun to spray a lite coat of Marvel mystery oil all over the under side, (except the exhaust )here in the deep rust belt it helps with corrosion control as well !
juanprado
2,866
Metairie/La (N'awlins)
my other lifetime selling parts screams what Daniel stated. Check Ball joints, but at this point if greasing stops the squeal, just know that is a temp fix and you should plan on some ball joint R&R in your future.
