- 10,859
- 745
- 113
- Front Royal, VA
Since I've had this truck in March, the truck has developed a leak in the outer rear passenger side hub seal, which would belch axle lube out during operation, and leave an unsightly blob of 90W gear lube on the hub. Eventually, if not dealt with, all the 90W would leak out of the axle housing through the bad seal, and you'd burn up your bearings and gears in the rear axle. Not good.
Today, I finally got around to playing with it. Thought I would do an interesting step-by-step to show my progress. Hope you enjoy my playing with the camera, and my truck.
Picture 1: The situation as is was. Leaky axle seal has puked 90W all over the hub. This is only the excess that has seeped out since it has been sitting. As it is flying down the road, the 90W is bring flung in all directions. Eewwww...
