Elektroman99
- 135
- 43
- Siegburg, Germany
Dear Steel Soldier Community,
I have a very serious comprehension problem.
In this thread I had discussed a starter motor that was constantly coming loose and we quickly found out that the rear fixation was simply not fitted and the starter motor is only fixed to the two strong bolts directly on the ring gear housing.
In this thread post there was a good video on how to test the distance from starter to ring gear. In the video, an Allen key is inserted between the engine starter flywheel and the starter shaft. In the video without the ‘rest’ of the car (engine) this also works. In my case, however, the starter motor sits in the housing of the starter flywheel (ring gear).
The photo shows my view when I'm lying under the vehicle and looking upwards.
How or from where do you get an Allen key in between?
What am I doing wrong?
Best regards
Elektroman99
Best regards
Elektroman99
