How To: Hub Flip
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
nice instructional presentation!!!
I don't intend to flip mine, but if I ever did I would certainly appreciate having this available to me...good work
1,129
Outstanding. I mean, that really breaks it down. I think we could link new guys to this who had seal questions as well.
Thanks!
Ridgerunner
Holland, Mi
mike,
Nice job, I'll be doing a hub flip this week.
I would add one thing though, that would come in handy when doing the flip. It would be nice to have the proper wheel bearing torque in there as well, to make it complete.
Install inner nut while turing hub & drum to 50 foot lbs. Back off 1/8 to 1/4 turn. Install lock washer and then outer nut. Torque outer nut 100 to 150 foot lbs. Safety the nuts by bending the tabs on the lock washer.
Torque for the axle shafts and drive flanges are 90 foot lbs.
hklvette
Christiansburg, VA
to replace the inner seal, does one simply need to remove the inner bearing to reach it? One of my hubs is leaking, and I intend on rebuilding it, so this will be a GREAT help!
mikew
edmond, ok
Yep!
Picture #14 shows the inner bearing on the axle tube, the seal is right behind the bearing. Just pull the bearing off the tube to get to the seal.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
I didn't see you mention the safety wire. Did you put it back in when you put the drum on the hub? Not being critical, just wondering what everyone has been doing.
mikew
edmond, ok
Of the four axels that I've flipped the hubs on, only one had safety wired drum bolts. The other three had "normal" bolts, not drilled for safety wire, they had lock washers instead.
Picture #11 shows the drum bolts before disassembly, and no safety wire.
mikew
edmond, ok
With the stock hub postion, the width measured on the flat part of the hub flange (where the wheel rim mounts) from one side to the other is 69.5"
When you flip the hubs that measurment goes to 79.5"... so it adds 5" per side, 10" total.
