How to mod engine can to test engine.
superburban
SL,UT
I had to do a little bit of modifying to my HMMWV engine cans to be able to start the engines in the shipping container. First, I lifted up the back of the engine by prying with a long 2x6, then I shoved a pile of blocks under the oil pan to support the engine while I removed the rear bracket. Once removed, I welded two extra angle iron pieces on either side of the original vertical peice, then I cut out a circle about 3" in diameter, where the starter cone would interfer with the brace.
Here are the before and after pics:
1,807
Now, once you establish what you need to know about one engine, you can take the modded mount from can to can rather than build 4 of them, unless you want to do 4 of them!
superburban
SL,UT
Yup! that's the plan. I dont see the need to mod each one.
Thanks for the help on doing this, 4x4.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Or, you could do it the easy way. I could have sworn we posted this already. Just weld an angle bracket to the back of the motor support and use spacers to the block.
1,807
Thats a good idea Gimp. I have to find a decent source for that virgin steel you folks use. Does Woodshole research labs know you guys have been taking angle iron from the Titanic crash site?
superburban
SL,UT
Here's some video of me test firing a 6.5 in the can:
[media]http://www.youtube.com/watch?v=5BAeJtO1YFk&feature=player_embedded[/media]
[media]http://www.youtube.com/watch?v=2Hd_hZG7q1g&feature=player_embedded[/media]
[media]http://www.youtube.com/watch?v=q1aGeMKWVrU&feature=mfu_in_order&list=UL[/media]
gimpyrobb
27,785
749
Cincy Ohio
Well Kenny, as much work as we do at Kip's farm, he has limited resources up there. Have to make do with what you got kinda thing.
He is especially lacking between the ears!
superburban
SL,UT
Congrats on a good engine!
How did you loop the oil cooler lines?
I removed one of the compression fittings from the block, took it to a hose shop, and had them make a 12" hydraulic hose with the female fitting on either end. It cost me like $23 at EVCO.
