how to mount spare super single on m813
seano11
103
Edmonton Canada
As the title says how do I go about mounting the spare tire on my m813 with 1400 singles the bolts are to short on the spare tire holder, What has everyone else done to mount it ?
indy4x4fab
Banned
1,711
41
indy, indiana
First off it can be done with what you have to work with, with a little work. first off cut off that centering wheel holder from the back stop plate. Then you will need to bend the ears of the tire spade out to the are flat with the spade. Then let them cool and re heat the ears again about 2 to 3 inches from the each side and re bend them back so that the spade will fit the bigger tire. Add a piece of chain or lenghten the spade rod, so that it will reach the hole. This will work just fine If you take your time. Now mounting a 16r20 in that location is a bit different.
