How to power 12volt civilian trailer
dlynes
41
Augusta, Georgia
Hello!
How do you recommend successfully powering a 12 volt civilian trailer hooked up to our 24 volt systems? Does anyone have a wiring diagram for the front or rear 12 pin trailer connector? I've read the E / 21 PIN is the power source. If I hooked that up to a 24V to 12V stepdown, would that allow the trailer lights to function from the cab? Could I remove the 21 PIN, wire it to a stepdown and then back into the connector? I would like to explore options before spending $355 or more on a plug and play adapter. Thank you.
Valley Rock
Big wheeler cat peeler
917
OR
On just your everyday basic trailer you only need four four wires .
1 left turn
2 right turn
3 marker lights
4 ground .
You can whip up your own pigtail for that in a half hour easy, as far as the voltage goes just switch your trailer bulbs over to LED, they don't care if it's 6 12 24 or 36 volt .
aw113sgte
1,365
La Crosse, WI
1 left turn
2 right turn
3 marker lights
4 ground .
LEDs absolutely care about the voltage. There are LED lights out there that have the circuitry to accept multiple voltages but they are in the minority.
aw113sgte
1,365
La Crosse, WI
Probably easiest option is swapping the trailer lights out for 12/24 volt types, then using a wiring converter (though those that are straight through wiring still look to be around $150 and up).
I went all out and got this one.
