lfhoward
- 40
- 18
- Philadelphia, PA
The 12-pin electrical connector cable on my M116A3 has seen better days. Although electrically it works fine, the rubber is so degraded that it leaves my hands covered in black residue when I plug or unplug it from my vehicle, and the rubber has cracked to the point that it is almost disconnected from the metal body of the plug.
I ordered a lightly used replacement on eBay but even that shows some cracking in the rubber. It will eventually meet the same fate. That is, unless there’s some way to stop the dry rot. Is there some kind of treatment I can apply to the rubber to make it stronger and less likely to crack and fail?
