How to remove M1008 Bed
24farragut
Wallingford CT
Looking to remove my M1008 Bed, so i can access the underside and really get off all the rust, then paint the axle and frame. Is this quick and easy, or not worth the effort? Can it be lifted off easily with two guys? Anyone know what the bed weighs?
1,806
Not really heavy but would probably take 4 guys to lift and walk it off. 8 bolts, unplug lights, disco fuel filler and it should be ready to go. May be a ground strap, don't remember.
GM72K10
61
Bucks County, Pa.
8 bolts, bumper can stay on. vent for axle, fuel filter screws, lights. Lift in stages with 4x4s and blocking. Have done quite a few but helps to have a forklift lol Take your time and be safe.
dunedigger
Hart, MI
I've done it by myself with a cherry picker. The biggest problem I have run into is the bolts get rusy and if you turn the nut on the bottom the bolt head stips out the sheetmetal in the box floor and then just spins. I've tried different ways of removing them, drilling the head off the bolt and drive it down, cut them from the bottom etc, all seem to be a pain.
GM72K10
61
Bucks County, Pa.
for rusted bolts as an alternative to the "hot wrench" I use a 4 inch grinder with the thin cut-off blade, cut the nut at an angle, you can get to all of them one way or another, works like a charm
ralbelt
9
West Warwick, R.I.
I removed mine by myself with the aid of a fork lift with 6'extensions. I had to cut one bolt out of 8. Light connections, vent, ground wire Rt rear IIRC, filler screws.. I took it off to do the same as you want to. Replace the rubber fuel lines on top of the tank while you have the box off.
24farragut
Wallingford CT
replacing fuel lines is a great idea. It is cold as **** in Ct recently, so i might have to wait a few weeks on this. Glad to hear its not too much of a big deal though, thanks.
