erasedhammer
- 58
- 28
- Maryland
Finally decided to tackle the electrical problem with the windshield washer pump switch.
The pump itself works when I manually ground the pink wire.
I can ground the pink wire near the pump, or near the switch (on the column) and the pump functions.
When I test continuity with a volt meter from the pink wire (pump side of the circuit) across to a ground point, and operate the twist stalk switch, I do get continuity.
So the switch appears to function slightly, but despite the continuity when operating the switch, the pump does not run.
I think it is a similar problem to when my brake light switch didn't work. That showed continuity, but was never able to illuminate the bulbs.
I suppose these old switches start to fail, and just wont work under load despite the switch still technically working.
So my question is, how do I rip out the old stalk and put in a new one? Is there a section in the TMs somewhere?
I do not enjoy steering column work, but it looks like this is the only way Ill have the washer pump back. Looks like the steering wheel needs to get pulled off, hopefully the whole column doesn't need to come off.
