How to tell if you need to change brake lining
dfanders
Yardville/NJ
Gents,
We are going to be installing new tires( Rims and all) on the M52. Since we are going to be removing all the Tires anywhy, i was thinking it might be a good time to peek in at the brakes inside the hubs, to see what condition they are in.
How do you tell if it is time for new brake linings? The brakes work fine right now..except that if you slam on the brakes, sometime the drivers side rear locks up. If you push gently, no problem, but if you stomp on it , you might get a lock up on only 1 set on one side.
Is it a big pain to get the hubs off to look at the brakes on a 1957 M52 ?
David Fanders
PS - Here is why we are getting new tires
area52
San Bernardino CA
They are heavy so have some helpers or a crane or something. I think one of the TM's has a measurement for the lining, no sure which one though sorry.
