How to test if front axle is working
sidewinder
Not far enough, PA
I was out tonight moving my 5 ton which one set of rear axles have been removed and bed shortened. I was on some ice/snow. Moving in reverse one rear wheel was spinning but the front did noting ( no spinning) Very cold out tonight. I had moved forward up some icy hills in the past and it seemed to work ok but can not tell if front axle was turning. What is happening here. Is front axle not working properly?
jatonka
87
Ephratah, New York
I think your air valve on the transmission top cover may be sticky or dirty or plugged and is not sending the air to your transfer case to engage the sprag unit into forward or reverse position. You should hear a shush of air when you go from neutral to reverse. and another shush when you come out of reverse. Please always use 1 st gear to start from a stop. JT out
cbvet
20
Northwest (Knox) Indiana
I put the front bumper up against an Oak tree, put the T-case in low range, put the trans in first gear. Gave it throttle & eased-out the clutch. The 1400-20's dug in.
Eric
CBVET
sidewinder
Not far enough, PA
Re: RE: How to test if front axle is working
I will check out the valve ontop of Trans. I have noticed that the air seems to hiss out from below the shifter(trans) until the air pressure goes over 60 psi then stops. When air is bleeding down it also starts hissing when air drops below 60psi dont remember if that was normal or OK
m16ty
211
Dickson,TN
I've got a big dirt pile on the farm. Every time I buy a deuce I climb the pile till all axles spin. That's how I tell if it's working. The dirt is loose and I'll useually spin out when the back tandems start up the incline or sometimes I'll make it to the top but if the front end isn't pulling it will spin out whenever the front tires hit the base of the incline.
