How to
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Try searching m819, or m246, or an m62 should work too. Only difference is a manual crane extension section.
EO2NMCB
23
DeSoto, MO
The 10 will explain how to engage the linkage to the left of the driver seat and the controls at the rear to choose between the crane or rear winch.
TM9-2320-260-10
Guyfang
23,406
Burgkunstadt, Germany
TM9-2320-260-10
if you look in the TM forum, the 5 ton and up , last page, last entry, all the TM's you need to use for the care and operation for your truck are there. The TM 9-2320-260-10 will explain rhe operation of the crane, in detail. It's the book we had to study before anyone would allow us to operate our wrecker.
Floridianson
2,500
Interlachen Fl.
Since your learning to operate it a good thing to do is check all gear boxes before hand. Then give the turn table a good greasing which is very easy with two people just watch your step.
