Huge tires......tire pressure?
BillIdaho
Caldwell, Idaho
I just had Goodyear 16.00x20's mounted on my M54. It doesn't wander from lane to lane as I was told it would, however it bounces pretty bad. What tire pressure should I start with? And can I guess changing it in 5 pound increments would make a noticable difference?
And how do I stop the nosebleed every time I climb up into it?
And talk about speedometer error........
emr
24
landing , new jersey
I do 20 # about incraments, and the 50 is the way to start, as for the pressure on the tires remember it says MAX LOAD tire pressure and that is exactly what it means !! and they are so over kill for that truck U have to just think it thru, why would they drift? I am not understanding the thought behind that? Maybe if U had bent rims? but im sure U do not, and they will go straght and tru, as long as your front end is tight.
Alredneck
Banned
1,494
15
TN
nopics I got a buddy Woodywood doing the same to his M54! I hope you got plenty of diesel! GULP!!!!!!
B3.3T
90
SW Ohio
emr, in my limited experience, drifting occurs with way too much pressure. It causes the tire to run only on the narrow center part of the tread and just drifts around. I had this on 14x20 ND bar grip tires.
hoopsoft
Purcell, OK
50 eh, I just put 1600 on the m816 and I started with 75, it bounces some but after a few miles seems to get better. Haven't had it on the road for any kind of distance though.
61
Capecod MA
[I have a M54A2 with 1600 tires. Started at 75 psi drove fine but felt every crack in the road. Went to 45 psi in the rear an 55 psi in the front(have a 45000 pound winch on the front} drives great much softer ride. I run 34 psi in the front and 25 psi in the rear out on the beach{ see pic}.
Ironclad
Las Vegas NV
Originally, the tires on my bobbed M52A2 were 90 psi all around. I changed it to 55 lbs in my front tires and 50 in my rear tires (see avatar). The drifting and bouncing has diminished noticeably.
Good luck!
alphadeltaromeo
Alto, GA
Great looking MV!
Andy
