hummer tires on a m1009
nighttrain2006
park forest ill
i would like to put military hummer tires 37/11.5/16.5 ( i think that the size), but i would like to put the rims and tireson my m1009. frist do they make a adaper to convert the lug pattern form 6 to 8 lugs?
if they do male a adapter where can i find them?
also will those tires clear for turning and height?
i currently have 31/10.5/15 rims and tires stock form miliatry
AJMBLAZER
Paducah, KY
Do a search, this has been covered a few times.
The short and sweet:
-Easier and cheaper than adapters 16.5" 6 lug wheels can be bought from major aftermarket wheel vendors.
-They're either 36x12.5-16.5 Goodyear Wrangler RT/II bias plies or 37x12.5R16.5 Goodyear Wrangler MT's.
-No, they won't clear without trimming and steering stop adjusting along with careful selecting of wheel size and backspacing.
-You're also going to really loose power with the big tires and pathetic stock 3.08 gears.
Hoot_223
on stockish 16.5 rims you can fit them on one with no lift at all, i put a set on my suburban awhile back
gocmndo
Centerville, Utah
I had a different experience....
Had my wheels and tires but not the lift yet and wanted to see how the tires looked. Would have worked great if I just never turned the wheel :lol:
I have a 4" lift and still needed to trim the fender.
Good Luck!!
AJMBLAZER
Paducah, KY
I had 36x12.5-16.5's on my M1008 when I got it. They were on OEM GM 16.5x6.25 wheels and they fit but trimming was necessary. There was NO way I could have run them without trimming the back of the front fenders and the front lip. Just turning on flat ground put them a half inch from the trimmed sheet metal.
Don't forget to adjust your d-side steering stop if it's a pickup and the passenger side if it's a M1009. Your drag link will thank you.
Bobert
Des Moines/ Iowa
I've got 33's on my m1009 right now. i whacked in the rear lip of the front wheel well a bit. They only rub when I hit good bumps while turning. offroad they rub a bit unles you go fairly straight.
I'm using 10'' wheels but stock ones probly wouldn't rub bad.
I put some 35's on a while back just for fun and I had to do a 6-point turn to get out my driveway.You might want to lift if a couple inches for 36's. I think alfa heaven put humvee tires one their 1009s looked pretty cool.
Here's a link to that thread.
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&p=209421&highlight=#209421
