Hummer Guy
- 784
- 93
- United States Louisiana
From the information I gathered, both of these fluids can be used in the 4l80e but GM recommends the ATF 6, I heard that the ATF 6 is a thinner fluid which can give it a better chance of leaking, which is why I'm asking this question. This is at least my 4th time having a leak with the ATF 6 after changing the gasket and trying to use a gasket maker one of the time. Each time I change the gasket, it last for about 3 weeks and then the leak comes back and then get bigger over time. The first time I tried an RTV and a aftermarket gasket, this lasted about a month and leaked (didn't know this RTV wasn't made for ATF till now), next I tried the aftermarket gasket itself and it leaked in about a week or 2, after that, I tried RTV itself, that leaked in a few days, and then now I got a new transmission pan plus an original 4l80e gasket from AC Delco. This lasted about 3 or 4 weeks and then started to leak. This is really starting to get irritating, is it something with the ATF 6 fluid that eats up the gasket over time?
My next plan is to try an actual transmission sealant that's made for ATF fluids.
