Humvee Gauges
jim1131
35
Illinois
Got a little acetone on my temperature gauge lens and now its foggy, I have a bad gauge with a good lens and wondering if theres an easy way to take apart the gauges so that I can swap lenses.
Action
1,557
East Tennessee
the bezel is crimped on over the lens. You can work your way around with a small tool. It won't look as smooth when finished, but the back edge will be hard to see when installed. Practice with the bad gauge since you cant see it anyways.
Mogman
9,503
Papalote, TX
Just get a new gauge, they are not THAT expensive, you will probably always have moisture issues with your rebuilt gauge, remember when it rains things get wet.
Maxjeep1
1,914
Las Vegas Nevada
Sand it with 3,000 and polish it out. Spray a little brake cleaner on a rag and see if it doesn’t take the haze off then polish it. Mine were really bad and they turned out really good
19,714
That will work - or old fashioned Colgate (the white stuff) tooth paste. Rub it with a soft cloth and wipe the glass (plastic?) clean with a few drops of water. It takes time, but sanding or tooth paste will bring it back.
Coug
4,298
Olympia/WA
when polishing plastic, if you try to go too fast or push too hard (typically when using power tools) you can end up overheating and causing more damage than you are trying to fix. Just something to keep in mind if you get one of those drill attachment buffing pads or something like that.
Maxjeep1
1,914
Las Vegas Nevada
Hahaha, you are right about that! Never use wool pad.. harbor freight has a headlight polishing kit with everything you need for around 9 bucks. It has arbor for drill and foam pads and it works really good. I was going to replace all of my gauges but after I did one I was happy with it
