Hydraulic Control Valve for Fan Clutch
StackJ
-2
SoCal
Just been reading TM 9-2320-280-20-1 and saw the following on page 69:
HYDRAULIC CONTROL VALVE - Directs hydraulic fluid to provide required pressure to actuate fan clutch as required by engine temperature. Hydraulic pressure supplied by power steering pump.
Which I assume means extended engine cooling (fan) is dependent on the power steering pump?
Has anyone bypassed this? Can you? Seems like one would want to keep both separately - like "your power steering goes out and you might also overheat."
Action
1,563
East Tennessee
the fan will default to ON if there is a problem.
the steering pump also put fluid through the hydrobooster for your brakes.
