- 6,438
- 8,990
- 113
- Papalote, TX
Hydraulic hose fittings? and valley pan?
Can anyone tell me what type and size hose ends are used on the hose between the Hydro-Boost and steering gear?
I want to get some fittings to make hoses for my Mile Marker winch and it would be much easier than taking them off to check.
EDIT Ok so I pulled the inside engine cover just to make sure the engine had not been swapped for a 6.5L thus my satisfaction with the power and no, but I did see the heater valve was not closed all the way (if my other post about the comparison of the HMMWV and the Unimog 404 ever gets posted this will make sense)
but another question has arisen, is there a drain in the valley pan or is water supposed to just collect there until it rusts out? I did dig around a little towards the back but did not find anything.
