Hydraulic leak
Blackmagic94
9
Oro Valley/AZ
Went to raise the spare tire carrier ram from the lowered position and I see hydraulic fluid steam and then piss out of a Black box with hoses next to the ram assembly but below the chemical detector unit mount. Any suggestions
Suprman
677
Stratford/Connecticut
Yes that's your air hydraulic pump. It has a bad internal seal and you are blowing hydraulic fluid out the air vent. Rebuild it. There is a thread that shows the part you need and the process. It's inexpensive.
