Hydraulic Pump...
rmgill
14
Decatur, Ga
So, on the list of things to do to the deuce, I'm thinking a hydraulic pump attached to my rear facing output for the double PTO. What kind of pump do I need to eventually get a dump rig installed?
ken
25
Houston Texas
Mabye you could use a 5 ton multifuel power steering pump? Anybody ever tried that?
1,128
Isn't that what gringeltaube is using for the hydraulic pump on his deuce dump conversion?
rmgill
14
Decatur, Ga
Well, I've got the rear facing PTO shaft on the dual output PTO. Seems like a shame not to take advantage of it.
gringeltaube
Staff Member
2,476
Montevideo/Uruguay
Nope! I used a small, external gear type pump, capable of well over 2500 psi.
PS-pumps usually are vane type and don't go much over 1500 psi.
Gerhard
1,128
Gerhard
Ah! My bad, sorry. :oops:
spicergear
26
Millerstown, PA
Any pump will just about do but a small pump or even PS pump will have lower volume and take a while to stand the dump box up. The pump I have on my crane is rating a little over 2000PSI and 25-28GPH and the crane moves with good speed with that. The mast raises with speed and the boom telescopes with speed as well, I use those two references as they are pretty decent sized rams like the dump will have. I'm using an older Commercial brand pump somewhat similiar to what Cranetruck has on his. A nice healthy gear pump will do you fine. Again, any pump will pretty much do but higher volume will mean faster lift rate. Oh, something along the lines of a 7/8"- 1-1/8" keyed shaft will make PTO drive parts easy to find/build. Tractor Supply or the like will have a good supply of U-joints, couplers, sprockets, etc.
TheBuggyman
Fredericksburg, Virginia
I used a generic gear type pump off of my rear PTO for my dump and it works great! I do not know the displacement (usually cubic inches/revolution). Verify the rotation prior to ordering the pump or just order a LH or RH rotation and assemble the pump as needed. Make sure you use a valve with a built in relief valve or you will have to add an external relief as a gear pump is a positive displacement pump and will pump until something breaks or explodes.
BTW- can you upload pics directly to this site or do you have to host them elsewhere and link them? I have some rough terrain/severely overloaded/converted dump bed deuce pics to share.
devilman96
17
Boca Raton, FL
Pics can be added via the "post reply" button to the lower left... Size must be 640 X480... there is a tutorial in the site help forum and I think Mike posted a tool for easy resizing in the tips and tricks forum.
M543A2
11
Warsaw, Indiana
Go to a scrap yard and get the pto driven pump off an older dump truck. Some of them have the valving included with the pump.Easier not to reinvent the wheel, so to say!!
