Hydro-boost bleed ?
jkcondrey
140
Rutherfordton, NC
Had the hydro-booster go out on the 1152. When replacing, TM -2 , 7-14, makes no mention of bleeding the unit. Is there a process someplace I am missing or it tied directly to the power steering bleed procedure? Thanks
jkcondrey
140
Rutherfordton, NC
I got around to swapping the hydro booster. Got a nos part. The pushrod on the master cylinder side is quite long, compared to the old unit over an inch more extension outward. I went ahead and installed and the brakes are locked up. Booster #’s said to match on rosy, but either it’s wrong part # or bad NOS booster? Anyone else ran into this?
Action
1,555
East Tennessee
may be useless info, but each different hydrobooster has different color studs. They match up to the master cylinder, i think.
Mogman
8,898
Papalote, TX
If it was the wrong one it would not bolt up to the master cylinder, my question is why install one that had an obvious defect?
jkcondrey
140
Rutherfordton, NC
Hmm. I hadn’t heard that. I’ll double check that. I do have a spare parts truck but the booster would be bad for sure, sat out in weather for who knows how long.
jkcondrey
140
Rutherfordton, NC
I wouldn’t know it had a defect from looking at it. For all I know the loss of brakes could’ve been that part of the booster. But sounds like Steve and Action pointed the right direction.
Thanks all
