hydro boost leaking M1008
bigmike
354
Dixon CA.
hey gang,
i've read thru a number of posts and am pretty sure my problem. I'm loosing power steering fluid between two parts of the hydro boost of my M1008. It's the joint right behind the power steering hoses. I've checked the bolts and they are tight. according to the TM, there is an internal gasket that looks like mr. peanut (cover seal #19 per TM 9-2320-289-34 page 726). Looks like it's part of Kit #2770723. I've attached a pic of the hydro. The two parts of the housing seem like a metal to metal joint.
Am i on the right track? if so, is it best to just change the gasket or get another hydro boost?
Cucvnut
61
Carver, Oregon
Well rebuilding is cheaper. I have to do the same. The rebuild kit costs about 20 dollars vs 168 for the new one and core cost.
Matt65
Alabama
Mine has been leaking for 2 years, but slows down conciderably in the winter -perhaps as fluid viscosity changes. I generally know the level is getting low when I begin to feel pulsation through the brake pedal when it is applied while turning.
mr.travo
Comfort, TX
1. I am sure I have the right tools, but what would be needed to rebuild it?
2. How long can I expect for it to take?
3. While doing it, what else would be good to tackle? Change the P/S lines and flush system?
bigmike
354
Dixon CA.
I struggled with finding the gasket kit. Mine was leaking pretty bad. I went ahead and swapped it with a rebuild. about $200.00 bucks later and i'm off and running again. The swap took about 3 beers to complete.
mr.travo
Comfort, TX
Also- if you don't want to rebuild it just go pick up one from Autozone. They work great too (as per my experience). It's a simple unbolt/rebolt application.
