hydro boost problems
marlink1226
stuart,Fl
Question, i have a 1986 cucv m1008 with the 6.2. I replaced the power steering pump and ever since have had no power steering or brakes. I'm on my 3rd pump and think maybe its not the pump so i replace the steering box that has a slight leak and still nothing. i bleed the system every time unless im doing something wrong there. the pump i got were from bennet and napa and im not sure the pump there giving me has enough pressure. i it a speacial pump or just a regular gm pump. any help would be great
MotorDaddy
Vermont
Just a guess, but I bet you don't have the relief valve in the power steering pump installed correctly. I remember this happened to me (years ago). When I swapped out the pump, the relief valve (that the pressure line comes out of) had a check valve and I screwed up the replacement order (ball then spring or was it spring then ball?) Anyway, no power steering.
73m819
319
gainesville, ga.
WEBSITE HELP is for WEB site problems, NOT truck problems, this should be in the CUCV fourm, makes search just a little better
