I’M BLIND!!
69DeuceJuice
81
North Carolina
I’m having trouble with my windshield wipers on my deuce specifically the driver side wiper. They are the original air style motors and the little red button is stuck pressed down in the housing.it was working before but it stopped one day and won’t work again. If I put air to it and pull the wiper arm over it will return but it won’t swipe as it should. If this something as easy as spraying some air tool oil in the housing or and I gonna need to take it apart and rebuild it?
Karl kostman
866
Fargo ND
Try a small squirt of lubricant in the air motor and actuate the wiper with the lever for a few swipes to spread the lube inside the motor and if that doesnt fix it then take the motor off and clean it up or just overhaul it or just replace it with a NOS one. If your really willing to get crazy replace them both with electric motors its easy to do and you will not have problems like this!
G744
3,703
Hidden Valley, Az
Air wipers are more powerful than any electrics, helpful if you encounter ice.
That button needs to be 'popped' out for them to work right.
The newer plastic motors are not repairable, all glued together.
The best were the vintage alloy Trico ones, easy to fix.
Wreckclues
504
Jefferson, Massachusetts
Agreed, easy to disassemble and mechanically straightforward. The problem I had with mine were the poppet exhaust valves. Ran the valve heads through an ultrasonic parts washer. Freed up the ports on one of the wiper engines. Although still having problems with one poppet valve on the other wiper.
msgjd
3,150
upstate ny
I have always used a good cleaning and then a spray silicone to bring them back .. It helps to PM them, shoot a little into the intake at least a couple times a year .. I concur with many that the all-plastic ones have mediocre to poor performance, and if you don't keep them lubed there might be no recovering the all-plastic ones from the dead
