i have an oil pressure issue !!!!!!!!! HELP
1973ih
Ausable forks ny
:?:ok i just did a cold start of the duce it was about -1 out i got it started and when i did my oil pressure was very low was 50 psi cold know 10 or lower it did take a wale to get it started and i did use very little starting fluid-i know its bad but started smooth whan i gave it a shot i did not use the heater when i gave it some ither and it runs just fine with know problems so please help thanks cody
jatonka
87
Ephratah, New York
Don't take this wrong, I have two things to say that are for others out there also. First, if you live where you know it gets cold in the winter, and you have diesel powered equipment, why not plug them in the night before you are going to use that diesel powered piece of equipment? There are coolant heaters, oil pan heaters, battery heaters etc. on the market for exactly this purpose. Loggers have coolant quick connects on pickups and skidders and loaders so the pickup can circulaate warm antifreeze through the cold diesel eqwuipment for a while before they start it, why, because they can't afford new engines all the while.
Second, just supposing you didn't need that diesel powered piece of equipment that day, and you just started it because you wanted to, there is an old adadge that goes like this: If you don't need it, don't start it on a cold day. Nothing good comes of starting a stone cold diesel engine if you don't have to:
Now, if you aren't real PO'd at me, I'll give you my opinion on your oil pressure drop. Because I assume it was totally not plugged in to oil pan and coolant heaters, your motor oil was pure molasses, 15w-40 is terribly thick at below zero, some brands worse than others. If anyone doubts me, put a jug outdoors on a zero or lower night, it totally shocks me everytime I grab a gallon of it on a cold morning. It's just about as stiff as 30wt motor oil. That thick cold oil is being pulled through two pickup screens in your oil pan that lead to the oil pump and those screens may have a little crud on them, so they don't flow perfectly.
Your system is working really hard to get the oil flowing, it probably isn't getting a full flow of oil, cavitation occurs and pressure drops. You will probably be OK when the ambient temp gets up around 30 degrees.
The guys here that really know me will understand that I am not being a know it all, and I wish you all could come up and visit at my place sometime so we could share experiences, cause that is what this is all about, sharing and helping eachother out when we can. JT out
Westex
El Paso, TX
dont worry the advice was well taken i just baught it and needed to move it but wouldent the pressure rise at full temp regardless of temp
I'm sorry, I'm sort of a fan of jatonka, but I don't understand your question. Could you please re-type it?
1973ih
Ausable forks ny
was wondering about my oil pressure being so cold here this might be leading to my low oil pressure but was not sure if it should rise at full engine temp i would thank it would hise ya know
