I know, I know..... Gen 2 light issues.
that1028guy
Florissant, Mo
:lost:I have searched for this and haven't found my particular problem. After reading a fue posts and looking at the trouble shooting book as much as I could stand. I am at wits end. I have an 84 M1008 90k mi The gen 2 light comes on and stays on, and the gauge at best will sit right between the green and yellow. I have checked both alternators at all the plugs. With the truck running, the first alt is putting out almost 15v (analog multimeter...ugh) and the second is putting out 26v. The batteries are showing 26v with the truck running, but the gauge and light are still as previously mentioned. I haven't pulled the dash apart yet to see if I have some bad wiring there, all the fuse able links coming off the 24v junction box are good as far as I tested. I tested the side of the black spool away from the junction box. I am thinking about replacing the gauge set with auto meter speedo, tach (if i can find it) oil press, oil temp, coolant temp, and trans temp. But I would like to resolve this issue first. And I suppose ask if I will be frowned upon for doing such gauge work. Any help would be much appreciated.
Ej
amphi
Onalaska, WA
that1028guy
Florissant, Mo
I read the post by warthog, I did check the 2 wire plug, and voltage is good there. You want me to check from where the 1st alt feeds the second to the output of the second?
Warthog
231
OKC, OK
A good alternator will put out ~14.7v.
If the first one is showing 15v and the second is only showing 26v total, then it is really only putting out 11v (15v+11v=26v)
It is time for a rebuild on the GEN2. More than likely it is the voltage regulator.
But for a few dollars more you can replace all the internals and install new bearings
that1028guy
Florissant, Mo
Just went and checked what I think you meant. KOEO 12 ish volts, and same reading KOER:cookoo: Where can I find rebuild kits for them? And thank you for all your help. Where should I post my story and pics of this beast?
Warthog
231
OKC, OK
There are many post on how to rebuild the alternator. The Tech Manual covers it step by step.
You will want a kit/parts for a 27SI Type 100 alternator. You can ask for parts for a 1985 Caddilac.
I have purchased acouple of kits from this place....
High Output Alternators - Alternator & Starter Repair Kits - Alternator Parts - Delco 27Si Type100 Heavy Duty Rebuild Kit
It does NOT have the Isolated Ground replacement parts but you should be able to reuse the old ones. Just some bolts and fiber washers.
Warthog
231
OKC, OK
With these readings it seems like your alternator is outputing 0v. The 11v you where reading are from the battery itself. 15 from the driver side GEN1 and 11v from the rear battery.
Time for a rebuild.
If you are not comfortable doing it most alternator shops can do it. They just need to be made aware of the neccesity of making sure the case is "isolated" from the internal electricals.
Almost all alternators ground the internal rectifier to the case so current will flow from the rectifier, thru the case, to the engine and back to the battery.
In the CUCV 24v system, this will not work and WILL let the Smoke Jeannie out of the bottle.
If you need more info, search for the Isolated Ground as there has been many threads post about it.
