I need 5ton Axle parts who to go to?
Steamynachos
Calgary Alberta
My 5 ton is leaking gear oil from the top of the 2nd axle back from the drive shaft seal can anyone suggest a good place to order 5ton rockwell parts from that would carry seals and the gasket I would need to fix this leak. :)
73m819
328
gainesville, ga.
that should be a standard seal, try matching up at napa truck shop, or any truck shop, or a bearing supplier, ps. there should be no up and down, or side movemont in this shaft/housing unit
