I need to disable my LMTV from starting... easiest way to do this?
graniteclimber
Anchorage, AK
1998 Stewart & Stevenson LMTV. I have to park it in a pretty sketchy area for a couple of weeks. What is the easiest way I can disable it from starting, short of removing the batteries? Are there any relays I can pull?
Ronmar
7,446
Port angeles wa
K1 or K2(starter and control relays respectively) you could also disconnect the solenoid on the back of the governor...
along the lines of disconnecting the VIM, you can pull the WTEC Circuit breaker which interrupts the start enable signal from the transmission...
Is your battery box locked, stealing batts is a popular pasttime I am told...
snowtrac nome
139
western alaska
I would have suggested relays they tend to be pretty obvious. the vim box is more of a secret for us fmtv enthusiast. As superman stated the best way would be a hidden interrupter switch.
coachgeo
3,461
North of Cincy OH
you may not want to as you mentioned "short of removing the batteries...... but that is really best if it is a sketchy area. Take them home some place you can lock them up after parking the truck. Solves the battery theft issues* of late AND the joy ride or worse of the truck.
*two trucks in last month on this fmtv forum have had batteries stolen.... even cheap battery replacements adds up to bit of $$$ when you need 4 and you don't have cores to turn in ta boot.
sandcobra164
295
Leesburg, GA
There are 3 switches on the passenger side frame rail just behind the front tire. One is a Battery Disconnect. Flip that up when you walk away and you should be fine. No one really uses those switches unless the cab is up and you're performing maintenance. Most people don't even know they are there.
coachgeo
3,461
North of Cincy OH
hmmm.... I don't think so....not on the FMTV's..... never heard of that in here. Maybe the A1's??? but pretty sure not the A0's..... but hey .... Ive been way wrong a million times. might be this is million and one.
sandcobra164
295
Leesburg, GA
You're probably correct, maybe it's just an A1 feature. All I've messed with is the ones in my National Guard unit have them. I get operators with that switch all the time. Sadly, my mechanics often overlook them as well when troubleshooting. Nothing funnier than seeing them hook a set of slave cables up (first remedy), then take the passenger side dash apart and start checking stuff with a voltmeter (2nd remedy) then finally come to me and say the battery disconnect must be bad. Flip one switch and the truck is magically "fixed".
BuiltMFG
Denver, CO
I saw those recently and can't find them in the TM's (I'm guessing it might only be on the A1). What are the other two for? I thought it was a way the engine off and on while the cab was flipped but I didn't have any luck.
Ha, just saw the post above this one, ignore the first note.
