Blood_of_Tyrants
- 10
- 38
- Lebanon, TN
O wise Steel Soldier sages, I need your wisdom.
I drained the transmission to install a PTO for a winch and looked at the stuff that came out and decided that it was too dirty to put back in. So I go to tractor supply and got two gallons of 90W/140 gear oil. Put in about 1 1/2 gallons and filled it up. The very first thing I noticed was hard shifting. So I think to myself, the clutch needs a bit of adjusting. After adjusting so that there is only about an inch of free pedal I checked the shifting (engine running of course) and noticed no difference.
So I look at the various manuals until I find that the proper gear oil weight is 75W/80. I'm thinking that I put gear lube that is far too heavy for the tranny and i need to drain it again and replace it with lighter weight oil.
What is your opinion, oh wise ones?
