Lonesome715
- 24
- 38
- Columbus, GA
Deuce trouble
I wanted to pick your brains and see if you could help me with what could be a major or minor issue with my 1987 deuce. I have only had to back it up a couple of times. Each time was a bit difficult but I just figured it was different from the older 67 Deuce I was driving. Now, it does not want to back up at all. It feels like the truck is backing into something and bouncing off. If I lock it in low it will back up but it really does not want to. At first I was thinking it might be a broken axle, but I should have trouble moving forward as well if it was. I pulled the rear drive shaft to see if that would do anything and it did not. This is a big problem I need this truck to drive back and forth from school. Do any of you know what I should look for or might this be a common issue?
