IBC totes for heating oil/Diesel
emmado22
147
Mid Hudson Valley NY
All,
I have searched, but cant find concise answers.
To store either heating oil or diesel in an used but excellent condition, food grade, cleaned out "doesn't smell of anything" IBC tote for 6-8 months, what type of gaskets should it have? I am not interested in using the ball valve on the bottom, I will try and cap it off to prevent leakage from it. Any other things I should be aware of? It will be stationary once put in place, and removed when it is empty.
Thanks!
Beyond Biodiesel
37
Prescott, AZ
An IBC tote should work fine for storing any petroleum distillate for years. The only problems that would arise are:
1) Breakdown of the HDPE from ultra-violate radiation from the sun, so it should be kept out of the sun.
2) Embrittlement from the cold, so it should not be stored outside in very cold weather.
3) Alcohol content in US American gasoline could damage the seals if it is over 3%. Note: winter US American gasoline can contain alcohol up to 10%, so a waste oil-gasoline blend should not contain more than 30% gasoline if stored in an IBC, or run on any diesel engine with silicon seals in the IP, such as the 6.2L diesel engine will have.
74M35A2
318
Livonia, MI
If the tank will not be in motion, I don't think the gasket material is of significance, except for the bottom ball valve (possibly those mount with sealant)? They usually have a large fill cap on top. Is this the gasket you are asking about? Otherwise, perfect answer just above this for things to consider, as plastic is nearly the same thing as motor oil/diesel fuel, from a chemical compatibility perspective.
Bo1
Central Louisiana
I stored my homemade biodiesel in one for years without issue. I also stored used cooking oil in one as well.
I currently work somewhere that uses them to store and ship paint all over the country. We recover the used tanks from our customers, wash them, and reuse them for years. IBC totes are tough.
lxawolf
Sussex, NJ
If your concerned for the gaskets new ones can readily be purchased from a number of online suppliers. I looked into this several times (my main stopping point is the wife) They also have the ability to adapt the 2" quick connect style fitting to various other sizes, for any number of multiple needs. One thing to consider if you plan to put a pump through one of the openings. The HDPE plastic is not strong or supported at the filling cap. So care needs to be used or the plastic can bend and develop stress cracks. As others have said, protection from UV is important. Not just for the IBC tote but also for the contents.
Ray70
5,687
West greenwich/RI
I've always heard that you can paint them with latex house paint to protect them from UV. I'd also be curious about algae growth if you are storing fuel for an extended period of time in an opaque container outdoors.
emmado22
147
I finally got a 330 gallon tote, used once, manufactured 3 months ago. Will work great for my inside extra storage tank. thanks for all the help!
