Identify this 6.2?
Dustinh
Auburn WA
Does anyone recognize this engine?
The only 6.2 I am familiar with is the M1009 version.
The pulleys and exhaust manifolds on this one look different.
Do you know if this engine could be easily adapted for use in a M1009?
The tag on the crate says 14022660
Is it likely new? Or rebuilt?
Thank you!
Dustinh
Auburn WA
HMMWV pullout. Could be new, could have something wrong with it.
Thanks for the reply.
I was hoping there might be some type of markings to indicate a rebuild.
If I inspect in person and it looks used, is it safe to assume it has had a major failure?
11Echo
92
CT W. R.
See this pretty engine. You could eat off it.
Pulled the pan and found a window into #7 water jacket.
Buyer beware.
Dustinh
Auburn WA
Buyer beware.
Thanks for the warning!
I will take that advise. That is not a gamble I can afford to take right now.
(I like the video in your sig)!
Warthog
231
OKC, OK
Buyer beware.
Hey I have just like that. Bought it from GL with a $250 bid.
The Green service tag read that it had a overheating problem.
Checked the compression and this is what I found:
1 - 220
2 - 300
3 - zero - yes zero
4 - 200
5 - 180
6 - 140
7 - 400
8 - 360
Since it is a 2006 model 6.5L GEP engine I expected(hoped) the factory 450 psi. I haven't had time or the desire to open it up yet. :-(
Could be head gaskets, cracked head, hole in the piston, or any of the above.
