Identifying 6.2 Engine
67_C-30
Sweet Home Alabama!
There is a casting number on left rear side of the block where the transmission mounts. There is also a date code that will be something like "D 15 4" or "G 20 6". The first letter is the date : A = January, B = February, and so forth. The first number (or pair of numbers), and the last number is the last digit of the year. For example, "D 15 4" would be April, 15th 1984
Your block should be 14022660, if original.
XENIA OHIO
There is a casting number on left rear side of the block where the transmission mounts. There is also a date code that will be something like "D 15 4" or "G 20 6". The first letter is the date : A = January, B = February, and so forth. The first number (or pair of numbers), and the last number is the last digit of the year. For example, "D 15 4" would be April, 15th 1985
Should have know it was going to be you. You are very helpful, I dont know much about these diesel engine and just trying to take in as much as I can
Block # is correct 14022660, on the right side it read this 9-7-82
now how can i tell if it is a j code or something else. Also should I replace the head gasket with .010 oversize . And head bolts should I replace them also?
Iwill be replacing all gaskets and seals . what about the timing chain ,should that be replaced. SORRY FOR ASKING FOR SO MUCH. Thank's
67_C-30
Sweet Home Alabama!
If it was a J code, it would have a non EGR intake and should not have the EPR (Exhaust Pressure Regulator) flappers on the manifolds.
The head gaskets can be stock with a turbo, but a lot of people use 6.5TD gasket to slighty lower CR. Replacing the head bolts are MUST. The factory bolts are TTY (torque to yield) bolts, they don't need to be reused. Upgrading to ARP bolts is a good mod, but new replacement TTY bolts will do. It would probably be a good idea to replace the chain, especially if the mileage is unknown.
1,827
While you are doing all of this work on your 6.2, consider replacing the harmonic balancer. With time the rubber allows them to shift. You may not notice it but the crankshaft will and eventually break.
Jake59
103
Kaggevinne, Flanders, belgium
GM 6.2 V8 Diesel Engine Number
Hi all,
Just wondering if anyone can tell me something more from just the Engine number about the engine itself?
6.2 V8 Diesel Engine Number is 14022660.
Any help appreciated.
Kind reagrds,
Jake
Jake59
103
Hi there,
Just new here and came across this message about 6.2 Engine Number.
Out of curiosity, do you still have that Engine # 14022660 in your truck?
Reason for asking... as strange as it may sound, I have just come across a 6.2 Diesel wit engine number... sure enough... 14022660
Just wondering how this could be?
Cheers,
Jake
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
14022660 is the 6.2L block model number, from 1982 up to year 1991. So there is more than one out there...:)
The engine's serial number is what is unique to each; found stamped in this area...
06TBSS
Huntington Beach, CA
Thread from the dead!
So my serial # behind Cyl#8 is UJN 024 so all the letters are past L(dec?) So what gives on my date? Funny way of spelling June? The last digit denotes '84 and thats the year of my M1008. The story is it is an outsourced reman engine. I guess the buyer requested or got lucky and given an 84 mill(not that it matters really). My Db2 is J code and #'s lime up w '84 specs also. My truck was built Sept '83 one of the 1st M1008s.
Im just trying to find out if I have Civy heads for the precup arrangement.
Kyle
Westminster, CA
