Idle surging
DoubleE
Minnesota
Hello everyone,
My Deuce has started surging real bad even to the point of quitting. It does this no matter how long I let it idle in the yard, but if I drive it to town it comes out of it. I did replace the fuel filters with no change. The only other odd thing I noticed was it seemed like the filter closest to the firewall was only half full when I pulled it off. Does this seem like an air leak problem to everyone else? Thank you for your time.
rustystud
2,820
Woodinville, Washington
Hello everyone,
Did you replace all three filters ? Have you checked the in-tank fuel pump ? If not then make sure it is working and pumping out fuel. Have you bypassed your Fuel Density Compensator yet ? If not then this might be a good time to do so. Your injection pump could be acting up. The droop screw could have come loose a little and is now out of adjustment.
DoubleE
Minnesota
Yes to all other than I haven't touched the droop screw. I've been reading up on adjusting it. Is it real touchy when making adjustments? Thank you.
