idle/wide open injector pump adjustment
robkiller
Colorado Springs CO
I am at the point where I need to re-adjust my injector pump I think.
My fuel shut off solenoid will lift but the unit will not start until I life the throttle lever (the thing that the fuel shut off solenoid pushes on) up a bit. I assume this is because it needs to be adjusted. It never moves from being all the way closed/down even when the fuel shut off solenoid is lifted. How do I do this? Also do I need to and if so how do I adjust for proper wide open?
Thanks again and again...
robkiller
Colorado Springs CO
I cant not find the directions on how to adjust this anywhere. Anyone have any knowledge on how to do this? The part I am talking about is on tm-6115-585-24p page132 figure 41 and is called the “the governor assembly”
Jimc
Mullica, nj
Rob the adjustmet is in the depot manual. 7-5 maybe.. Or around there. I was looking at it yesterday. If you lift your shutoff solenoid the governor arm should lift the throttle arm almost all the way up. Thats when its not running. Basically when its off that gov arm should be way up and the shutdown solenoid, when released, should take your spring loaded brass linkage rod and extend it quite a bit to completely shut the unit down. If your gov arm is not putting tension on the linkage the spring may be missing
robkiller
Colorado Springs CO
I will look thanks. Its not moving it at all so I will take a look.
Munchies
Keesler Air force base/ MS
If there is pressure being applied to the throttle arm on the IP it should raise. Problem is corrosion and gummy crud sticks up the shaft and assembly that is on the other end of that throttle lever. With fresh diesel in it, if you gently coax it up and work it back and forth you can un stick it. It may take a long time (1-2) weeks of starting it every day and working that arm in it bottom 3/8 or so of movement to totally free it up. Dont force it.....
