- 1,651
- 1,664
- 113
- Nova Laboratories, WA
So....I got muh handy dandy meter, TM, and some civvy diagrams...
I isolated the ignition, accessory, and starter wires..
I'm getting +12v on both red wires at all times...
Brown is accy...
Yellow is start...BUT....I'm showing 24V on crank....shouldn 't that be 12V? 12V to operate the solenoid/relay which then puts 24v to the starter?....
I also have a mystery brn/white and green wire in the mix which I can't identify....The civilian wiring says brn and white it's hot in accy but it's not hot in ACC or RUN.... green says ground but shows no continuity in any position..
Any insight?
Brown is accy...
Any insight?
