- 26,246
- 1,176
- 113
- NY
I recently ordered purchased a new ignition switch box that mounts on the steering column of the Mule.
I have an extended shift lever so I modified it (bent it) so it does not touch the box when I bolted it to the column. I mounted it about half way up the column.
My question is, what are you guys using for switches? The box came with 2 holes in it. I am considering using a lawntractor style switch(with magneto grounding). They all seem to have an off, on, lights on, start positions. I would like to add lights eventually(no alternator yet) since I do drive in off the ice at night all winter long. I've been thinking of using led lights.
I have also considered installing a horn eventually.
I could just relocate the original 2 switches into the box, I think?
What do you have for switches in your box?
