2deuce
- 147
- 63
- portland, oregon
My ignition switch is giving me grief. It sticks coming out of lock like I have the wrong key but if I wiggle/jiggle it will turn on eventually and then turn to start with no sticking. Anyone have had this problem, it seems to be getting worse. Could it be the lock cylinder or the locking pin that locks the steering wheel. When I shut the truck off it works smooth. Is putting in a new switch a headache? I saw there is a plastic cover on the back of the column opposite the switch. Can it be removed or do you have to pull the steering wheel and go down from the top? I couldn't find any info from search. Thanks
