- 3,138
- 159
- 63
- Huron National Forest, Michigan USA
My M882 started to cut out on me once in a while.
It would loose spark and die, sometimes start right back up & sometimes it would start again later, got worse to the point that it wouldn't start at all,
I swapped out misc parts one at a time to track it down, the resister, the coil, the (electronic?)module on the fender, then I started to check under the distributor cap seeing as the coil had power, I 'flicked' the pickup coil a bit and it would run sometimes, so I ended up buying a rebuilt distributor for a little over twice what a pickup coil would cost.
I swapped it out it had spark for a few seconds and died, <img src="emoticons/icon_smilie_bitchin.gif" alt="Bitchin">
I went through everything again including cap & rotor & even the coil wire! and back to the control module on the fender, which this time fixed the problem.
Questions;
1. how can I test the old pickup coil to see if it was bad at all?
2. Could the pickup coil have fried the control module? or vice versa?
Questions;
