I'm having some Tapatalk issues
1,163
I know that Patracy has very little control over TT, so I know this isn't probably isn't an issue on our end.................... but I am having an issue where when I look at threads on TT, I see the posts, but they're blank. No words or images. If I swipe down, the text "flashes" and then immediately disappears again.
Is any having this issue and does anyone have a fix for it?
Here's a screenshot off my phone. You can see there is one post in the thread, but it shows as blank in TT.
5,167
I know this is a lame question, but have you removed/reinstalled it? The fact that it displays the text but flashes means it's getting data (IMO).
1,163
I had not. I just uninstalled and rebooted and installed a fresh copy and I guess I was running on an obsolete version. I seem to not be having the same problem, but the new version appears not to have the "front page" like the old one................. does the current version require you to go in to each forum to view unread threads?
5,167
I'm not failure with it, I browse new posts from a computer and use tapatalk to reply on the go.
