I'm missing a relay
marcos
new jersey
hello guys, after 1 year with my 803a I managed to turn it on after making the oil changes and all the filters, it started very well without any problem or even throwing up a lot of smoke after 7 years without using (very happy:D:D) the only problem is that electricity is not produced, I have realized that some of relays is lost ..
My question is if all the relays are the same, here I leave you a photos so that you have ideas..
The first one from right to left.. can I buy one like the others..Thanks
marcos
new jersey
One question, for that reason is that the generator is not producing electricity, because I do not have that relay working or there may be another reason why it does not produce electricity
robertsears1
119
Near Apex/NC
So if we understand you, you have just gotten this unit running and have never seen it working correctly. How did you acquire it, and was it demonstrated before you purchased it?
Robert
marcos
new jersey
Robert
I bought it a year ago, I sent it to an island in the Caribbean (Dominican Republic) now it's the time I turned it on but it's not producing electricity..but I have one relay missing,I already bought one and it"s on the way.
marcos
new jersey
Put these numbers in the big auction site. Cost 24.00
5945-00-458-3351
KUP14D15-24VDC
Thanks Guyfang I already bought this one on Ebay,my problem is that I"m out of the USA and I have to wait like 10 days to get it,meanwhile I woudlt like to know if there is something else that I must do to figure out about how to get power from the generator
jamawieb
536
Ripley/TN
The relay your missing is the oil pressure relay. Part of the system that excites the field I believe has to flow through the oil pressure relay so with it missing you will not get power. It's raining for the next 3 days here, when it stops raining I'll go out and pull my relay to confirm the theory, with it missing.
Guyfang
23,256
Burgkunstadt, Germany
Can an you read a schematic? If so, you could use wire to jump that circuit. Would I do that? No, not unless it was life or death situation. Because if you get it wrong, you could do much damage. Or if you had no oil pressure, the engine could destroy itself. Not good. Like LITD posted, your best bet is to wait a few days. You have had the set this long, a little while longer won't hurt.
marcos
new jersey
I have to wait for the relay to arrive, I have good oil pressure Guyfand I have a question that I would like someone to answer me, if it is possible that for lack of this relay is the reason why Im not getting power??
Guyfang
23,256
Look at post #13. Jamaweib says it all.
Normally the set will not start without the K20. How are you starting it? There are ways to cheat the safety chain, like any other electrical device. If you know what you are doing, you can start and run the set with no relays. But they are there for a good reason.
marcos
new jersey
The generator turning on and running like a champion,all the gauges works perfect except the ones for the power(percent rated current and AC Volt)
marcos
new jersey
SOS..hello guys today I got the relay immediately replace it, but I still do not get electricity, now I realized that turn on the light of the AC circuit interrupter only when I put it in the position of CLOSET, if I put it in open, turn off.
is this normal ??
On the other hand, the Convenience Receptacle is only giving 25 volts.
only 25 volts from the lugs
