In search of an oddball trailer.
BillIdaho
Caldwell, Idaho
I am in want of either the M762 version or the bigger 3/4 ton version (I don't know the "M" series number for the 3/4 ton version) trailer that has the crank-up antenna mounted on its bed. Usually the antenna is about 40 feet tall when raised, and pivots flat to travel when cranked down. I have seen several of the smaller M762 versions that had outriggers on each corner for stability. I don't know if the larger version has them.
It doesn't need to be in perfect condition, actually I would prefer to find one priced to fix up----within reason.
THANKS.
Angelo
Hi Bill,
I have the M762 3/4 ton with the stabilizers and the CRANK light tower (looks like 3 section of 10ft each) in DRMO conditions. The gen-set and the fuel tank are not there as per demill, but the guy who sold it to me had an industrial ballast installed to work the lights. If you are going for the antenna set up you may not need the gen set after all. I can email you pictures if interested. Located on Long Island NY price is $2500.
papocchio@aol.com
OldVet
Bill,
Are you still looking for this trailer?
I have seen what might be the mast for one.
It was triangular with several sections and had a boat type winch and cable to extend it.
A ham buddy of mine has it and I don't know what is planning to do with it.
OldVet
